Does anyone use CatchON or a reseller that uses the Netgo branded app? I’m considering the service and possibly becoming a reseller and would like any feedback on the service?
Fantastic service. Been using for about a year now and only experienced one outage wherein service was down for a few hours.
Most channels are 4k, rest 1080p. Updates are frequently delivered with seamless integration. Excellent customer service via chat. Nice selection of channels that you can filter as desired. Only downside is you must use their app (sideload it). Otherwise, Excellent service.
BTW, buffering and streaming issues are rare. And are usually caused by my VPN (SS) when they do occur.
Thanks very much for the feedback! I am on a 36-hr trial now and so far I really like it, except that I can’t use Tivimate. However, their app is good and I don’t dislike it at all.
They can’t or won’t tell me which reseller panel they provide though and that is an issue as I want to know if I can use the WHMCS Smarters billing panel if I resell for them.
Do you have a url for theyr site? I’d like to check it out
(@ blainep3) Glad you like the app. I don’t know what reseller panel they use but they are formerly known as Falcon TV if that helps. GL2U
Seems like a decent IPTV, hearing issue requires me to have subtitles. They do not have CC available.
