Carnage TV and vod
“Carnage TV and Vod” app download code 2536651 is a free service that I’ve been testing and I definitely think it is excellent. The only problem I had was when using Surfshark, the program would not run. That took awhile to figure out. I was on Surfshark support for 2hrs 20 mins yesterday and how it ended was Tech said “Oh by the way we don’t support that program” after 2 hours and 20 minutes working with them. I installed the FREE ProtonVPN and Carnage TV and vod are working with a VPN now. It almost resembles LayerSeven except it’s free. Something to consider.
Great app! Thanks Franksr!
Thanks Franksr.
Interesting but getting a lot of errors that I don’t get with other apps (“no internet”, etc). Also, would be nice to block the porn options for general use.
Easy, set up parental password and lock the porn out.
I was experincing buffering. It did it 3 or 4 times and then it played the rest of the show buffer free.
Last night I was watching a TV show and it kept buffering using LayerSeven and then switched to Carnage and it was doing the same? I couldn’t find any way to eliminate or hide the porn channels either. However, overall for FREE, it’s an option. I thought it was worth sharing. I did state that using Surfshark it would say NO Internet. I have Surfshark now looking into that. I used the Free PROTONVPN and it allows Carnage through.
A good free option. When I was testing, I did get a lot of buffering and audio and video was out of sync. Also got the ‘No internet’ upon launching.
Absolutely!
You can’t hide the porn channels but you can lock them out in Settings (see above).
I get “no internet” randomly, both with and without Surfshark (?) Restarting the Onn box clears it (I get that on a couple other live TV apps too).
Is it down now? I get webpage not available.
Mine’s working (well, 95% of the time).
Sorry, I wasn’t clear. I don’t have the app yet. I tried the downloader code and got Webpage unavailable. Is there a new code?
The downloader code for Carnage TV&VOD is 2536651
Great. Thank you.
I thank the Carnage app is down right now Can’t get any channels to play.. It was up yesterday morning but now nothing.
Yep it’s down for me too.
Maybe too many people are trying it since the discussions here?
Their’s only ben 5 post about it on here before it went down .
only 5 posts but almost 600 views….
I clicked on it 550 times!
Isn’t that 1100 views? Two eyes, right?
