I am trying to use downloader for mx player.
I get a captcha entry screen.
It wont take keystrokes.
I did a search and that post mentioned a problem during ddos attack…that was resolved…?
what am I doing wrong ?
my downloader version is 1.4.4
Make sure javascript is enabled in downloader settings
thank you TXRon that worked! It’s downloading now
Here’s a recap of my problem and the solutions as fyi to others.
Cinema V2 was not working with MX Player. MXplayer crashing randomly.
Tried to use downloader to get new mxplayer from troypoint.
downloader asked for captcha. keystrokes not working
i got MXPlayer from PlayStore.
It works with Cinema, but tv shows have to audio sound.
Played with settings no good… codex missing ?a way to get you to buy pro?
Found downloader captcha solution = enable javascript.
got MXPlayer from troypoint
ALL IS GOOD
