I came across Speedify which claims to be able to combine multiple internet connections into one. I have only one ISP service but can connect to multiple devices at the same time. Is that what they mean by multiple connections? Speedify claims to work on a Firestick 4K so would it be possible to pipe TiviMate through it? Thanks.
I think you are misunderstanding multiple connections when it comes to iptv… You only have one ISP locked to you, you cant get more… IPTV providers set a certain amount like 1 connection or 2 etc… this means if you have one you can only watch it once and someone els in a different cant watch it at the same time as you, its like when you pay for Netflix and have 2 screens, a 3rd cant be used at the same time.
Got it. Thanks for explaining.
I’m going to switch from having 1 connection to 5 connections on my IPTV provider. Can each of those connections on different devices each have different favorites and separate from the others?
Yes.you can
