Can I load IPTV into Superman Kodi build?
I have superman build on my kodi. Troy talks about the best IPTV apps. I want to know if I can download to Kodi with Superman build already onboard. The normal way doesnt work and online info is not working either. Is this possible. Thanks Brent Rubin
That particular build has some free live tv applications built in. If you want to add others generally you would do this thru the repository.
