When picking a torrent better cached or uncached? Thanks
I think I’ve been using cached torrent files, but in truth, I haven’t really paid attention (are you assuming that the files that don’t specifically say “cached”, are uncached?). If memory serves, most of the torrent files that I see are cached.
That said, whatever type of file I choose, I try to use keep the file size less than 5 GB (usually somewhere around 3 to 4 GB) to avoid buffering! I’m using Cinema pretty much exclusively these days, and so far, so good!
Thanks for replying , I mostly use the crew, works great also Seren, crew is also the only one that removes duplicate files (I think) ,
For me wgem the links load I see cached and un, IME the cached work better, load quicker
If you’re on RD and believe you need to be to see them, it doesn’t matter. Just pick the best link you feel best for your needs.
