Cache Management
I hope that I can ask this question. Is there a way to automate the clearing of cache on my Nvidia Shield for Kodi and all other apps?
If you have a number of apps loaded and then shut off double clicking the home button should remove the cache files.
You can go into settings >device Preferences>Storage as well
Or download App Killer and Cache Cleaner from Techdoctor on Google Play. These to apps work great for me.
But on the Pro there is absolutely no need to add extra apps that only do what you can already do yourself in the pro.
To be specific, I am running Kodi on the ONN 4k Plus Box. Almost daily, I have to clear the cache in order to have Kodi start-up. Is there a solution or setting that I have missed eliminate this issue?
Get the Onn Pro.
Powerful Performance: Features 3GB RAM for super smooth app performance, fast navigation, and seamless multitasking.
  1. Expansive Storage: Offers 32GB of storage, allowing for more app, game, and content downloads.
Using the search>magnifying glass on the header, will help you find the answers you need. Lots of info to search and read.
