Tried to.install Xenon build yesterday but unsuccessful getting past install from zip file. Diggz zip file won’t go to repo…suggestions
Maybe recheck the url your using or Maybe the repo was down yesterday not sure, but I do have xenon build on troypoint’s 19.0 fork and it works great on the x5.
no zip files, just apk’s on initial install. All internal zips are handled by kodi itself. Its possible they are working on the build and you are having trouble accessing it. Try later
edit…also make sure unknown sources is on
Ok. I installed Seren and the Crew with no issues. That’s basically all I use Kodi for anyway. Sure miss Cinema HD
