Originally published at: BuzzTV XRS 4900 Review - IPTV Android TV Box
This BuzzTV XRS 4900 review was written by Troy after using it extensively for two weeks. The BuzzTV XRS 4900 Android TV Box has received a lot of praise. It’s considered by many as the best Android TV Box on the market today. The architecture of the BuzzTV XRS 4900 is based off their built-in…
Is this box good to go and work in Australia?
Hello, as long as you have Internet it should work from anywhere. You may need an adapter for the power plug as I don’t know what your typical one is.
I’m slowly installing apps and getting my 4900 as I like. However, I’m having a heck of a time loading Kosmos stream on Syncler. I have tried everything imaginable to get this going and it just keeps rejecting my Bouncy input. Any help would be appreciated?
I cant figure out how to load my IPTV provider to use the DVR. I am using
GloryV. What type of code do I need to enter to get my live TV working with the guide and DVR. I have no trouble using GloryV with Myiptv.
Thank you.
Hello, in Server Settings you can enter either your Xtream Codes or M3U setting. One or the other. You get those settings from your provider.
