Has anyone been experiencing micro freezing on their buzztv x5 128.? I have had this issue with mine. Replaced box with KM2 same source and no buffering or freezing, making me suspect the box is the issue.
Thanks
Have you tried swapping out the hdmi cable?
Thanks will give it a try.
If thats not it then look at refresh rates
Thanks… Appreciate all your suggestions. I have been trying to figure out what is causing it for a while now
Hope you get it sorted, The X5 is a cadilac
