BuzzTV Gen 5 MasterClass & Buyer's Guide
Lots of questions lately on how to setup and use BuzzTV Gen 5 Android TV devices.
Here’s a 7-part video series and buyer’s guide.
Thank you troy and team, i really hope this helps others. I’m also glad we have a buzz support guy here as well.
The chart says yes, but I just want to be clear before making a purchase, the backlit remote would be the same type of back lighting as the Nvidia shield or fire TV, pro remote?thanks
BT-400 has a bright backlight.
BT-250 does not have a backlight.
The model you buy will vary depending on which remote you will get.
Thanks
@buzztvglobal
Just wanted to say good job on the updates. That bt remote is very snappy works well. The unit is fantastic. Huge improvements on the ui. I havent did a deep dive yet, but everything i did works well.
Also thank you for helping with support.
Where can I find the BuzzTV Gen 5 MasterClass seven videos?
They don’t seem to be attached to the review
Here you go - https://troypoint.com/buzztv-gen-5-masterclass/
I just changed iptv services. I deleted the old one from BuzzTV. It worked until midnight, just being set in Tivimate. Then I got a 405 error. Went into Buzztv5 & changed it there, also. Now, Im getting this Software caused connection abort. Any ideas? My other connection is working.
