Buzztv 4900 box folders n recording
I just put in a 2.5 hard drive in it detects it but cannot figure out hoe to record to it in tivimate it will not give me the option to record to the that drive plus i like to add folders to it can anyone direct me thanks
make a folder, name it whatever and place it somewhere like the download folder then in tivimate point it to that folder to save recordings
I am trying to figure out how to make a folder when i go to storage & click on the device it won’t let me can’t find nothing on the web
you need to go into file manager with x-plore or another manager open the download folder then click create folder, it should put the new folder in the download. After that then you direct tivimate to that folder.
