Buzz P6 crazy sound issue
when i first hooked up my P6 i use a HDMI to Display port adapter to my old Samsung computer screen which it worked perfectly i hook up all different streaming boxes to that screen to test them out i also used the HDMI on the screen but i switched the P6 from display adapter to the HDMI hooked to the screen now this is what i do not understand when trying to play any side loaded apps on the P6 no sound but my tablo,you tube,Pluto,ect all have sound i don’t get it now if i pair my blue tooth sound bar with the P6 then i have sound with all my side loaded apps like stremio,nuvio,kodi ,ect so i hooked the P6 back up with the HDMI to display adapter and now same thing no sound on side loaded apps but worked before i switched any one have any ideas and as always Thanks
