Builds that work on Kodi 19.3
@Bug
I understand, I get it’s a learning curve for some. I can appreciate the time it takes to learn and you are doing good.
What I mean is the troy app as a unlinked program. And there is a debloat tool.
For kodi, I would just install 19.3 and follow the guide for addon the crew oath and seren.
Builds take up space. Plenty of guides on here for unlinked and kodi no builds.
I hope this has helped.
I’ll work on that…thanks. I’ll repost to let you know when I straighten things out. Thanks for the pro tips… I appreciate it.
Willie75…thanks for your imput; appreciated.
Diggz Build works great for me. I had to reinstall once… I think they had an error as when I tried it on 3 different devices (4K FS, MeCool, etc) it didn’t take… then a few days later it installed OK. I think a link bug was fixed. I’ve tried a few other builds but the Diggz is the ‘prettiest’ and nicely laid out. Give it another whirl… am sure you’ll be pleased.
Dracco…I solved my issue. All is now working. Thanks!
@Bug
I’m happy your issue is resolved. Enjoy.
