https://www.xda-developers.com/reasons-bufferbloat-worst-networking-problem/
and a recent post/video by Troy helps to eliminate these type issues. ![]()
I donât think that helps fix the 3 buffers that cause bloatware, but I havenât dug deep into it. Buffer bloat needs special tools to even measure it. The usual speedtests donât even show it. From my understanding you need a modem with certain additions to lower the buffer bloat, something called SQM.
Smart Queue Management (SQM) is a network system that improves a routerâs performance by managing network traffic:
just an fyi buffer âbloatâ can be caused by many issues most often by bloatware added to android boxes/phones etc. The term âphone homeâ is often the cause as the box is doing so much un-needed task in the background. Removing these task or at least turning them off can reduce buffer and also help with other issues such as heat which we all know can slow a box down. Windows users encounter this same issue on the desktop due to microsoft background task running.
Excellent info tx Ron. The article I pointed to focuses on the modem/router and how to reduce any effect overloading the 3 main buffers, used by them, can cause, whether unneeded apps or addons. Now to see if I can access my ISPs supplied modem and activate or enable SMQ. I suspect not but certainly will add this to a discussion Iâll have with my ISP and see if itâs something I can get in an upgrade from them. Fortunately my Modem never seems to get overheated and I keep my system cleaned out of unneeded stuff.
Not sure if itâs happy or merry boxing day. ![]()
Analiti shows Buffer Bloat now.
I did notice that, but not sure what I can do with my modem to mitigate any issues. Always so much more to learn. I did use the special tools and ran a test and my system rates a B, so there is improvement I can do.
Yes itâs not for the novice. And the Router needs certain things. Easiest fix is a new router with the latest specs.
I was wondering what that was when it showed up.
Not so much these days. The three web-based speed tests listed on What Can I Do About Bufferbloat? (Speedtest.net, Waveform, Speed.cloudflare.com) all give accurate measurements for latency during upload and downloads (âbufferbloatâ).
It also provides concrete suggestions about what changes you can make to minimize any lag that youâre seeing.
The problem I am finding is widely varying results speedtest.net and cloudflare. Thanks for the informative site. Always appreciate added sources.
Try using Speedof.me best real life results
garbage/cheap hardware and link saturation.
least expensive option can be found among those capable of OpenWRT
I have looked at SpeedOfMe. I think its speed measurement is accurate, but I donât believe it measures latency during download or upload. That means it wonât detect whether your router is buffering too much data (that is, whether itâs prone to bufferbloat).
See also the âbufferbloat loadâ question at the Bufferbloat FAQ
⌠least expensive option can be found among those capable of OpenWRT
I agree - the OpenWrt One router (US$89) is quite capable and has all the bufferbloat fixes for ISPs and WiFi built in. (See the What Can I Do About Bufferbloat? page for a link)
34 ms isnât that much, especially with your speeds. But if it gets fatter than 50, Iâd definitely put it on a diet. ![]()
Hey Miki, Itâs been a while since I have annoyed you so I thought I would rattle your cage. I hope you are having a good holiday season and I wish you the best going forward. I also wanted to take this opportunity to ask you about your latest post on Bufferbloat. I ran a scan through Waveform and it graded performance a âCâ. Pretty mediocre, right?
So, at a glance it looks I have a problem. But do I? I have 1 gig from Spectrum and it seems my system is getting most of that. So, I went to the âfixâ part and it suggested i could upgrade to an EERO mesh. Which is what this is running on. EERO says I could improve things if i turned on âOptimize for Conferencing and Gamingâ. It also says it is âbest for internet connections under 500 Mbpsâ. Clearly my speed is well above that. So, what I am asking is, from what you see, do I even have a problem or is the âCâ grade an anomaly? Thanks pal.
At those speeds I wouldnât even worry. Unless youâre Gaming I canât see youâll have any problems at all. 13 ms is so low I doubt itâs affecting anything. Now if you were above say 50 I might do some digging. Sometimes these tests cause you more worry than there worth. Your upload speeds are killer. In my personal opinion Iâd uninstall the test and forget you even used it.
This is exactly why you are such a great resource. Thank you my friend. Being a great resource is both a plus and a minus, right? Sometimes Iâll bet you wish the âGo Toâ was someone else. haha. Thank you again, sir.
Iâve been wondering where the bufferbloat âfatpointâ is - so thanks Miki!!!
