Which repository can I use to install Boxset Kings Reborn add-on on Kodi 18.9? I’ve tried CellarDoorTV as recommended but nothing is there, so is it still on and working? And if not can anybody recommend a similar add-on?
Thank you.
Don’t know if this is still good. repository.cdrepo-x.x.zip . looks like it is for Kodi 17 and 18. HTH
Thank you for your reply/advise, this is the cellulerdoor repository, which I mentioned that it doesn’t have anything inside it.
Sorry, doesn’t look like it gets updated.
