Homelander addon has multiple free links, some of which are 1080. The good news is that Homelander is located within the Crew repo, so if you have the crew installed just go to “install from repository” and install Homelander and try it out. (takes about a minute).
Unfortunately, if you buy Amazon, you will be stuck with their bloatware. There used to be a utility to turn the programs off and regain memory, but Amazon’s latest update made sure that tool doesn’t work now and made sure Launcher Manager doesn’t work either.
Number one: there is no application which will deactivate forward slash get rid of Amazon fire stick bloatware. Correct?
Number two: if that’s the case, would you recommend expanding internal storage through the method Troy suggests in his tutorial? That is, a flash drive, and that particular cable? Neither seem overly expensive, but, would this be helpful in terms of expanding storage?
As far as I know, nothing can delete the trash Amazon puts on there. I would definitely recommend expanding the storage, but would tell you to get a little higher quality flash drive so that you don’t have any issues loading and streaming.
Jailbreaking the 4k max is a little different than on the other firesticks. *Go to settings - My fire tv - about. Now select Fire tv stick and click it 7 times. That will enable developer options.
