Gotcha, Thanks
Hi SoloWarror, I’ve tried 2 of your urls but they both failed to update.
I was using extreme codes. Are your urls extreme codes?
When I went to put in the new url, in Tivimate Playlists then clicked on my url and deleted it. I put in the new url then updated playlist. It came up updated failed. I know the internet is working and the url was correct. Did I do that correctly?
Hmmm it sounds like you did it correctly. I’ll try and walk through step by step . In Tivimate choose Settings, then Playlists, then select the playlist, then select Xtreme Code Parameters, then select server address, then edit the URL to oner of the ones I posted and it should work. I’m using the last one http://cf.one-cdn24.me It’s working perfect right now
After entering what you said do I go back to playlists and update?
I found the apply changes so I clicked on that and it’s working. Thank you so much SoloWarrior for your help.
Have a good evening and rest of your week.
They didn’t work for me at first. I remembered that I was using xtreme codes. SoloWarrior walked me through the process and it is working now.
The url I used was http://cf.one-cdn24.me.
I’ve been having problems with the URL given to me by Amber. I get the Chanels and EPG info but no video. Tried Solos URL .. everything is working .. go figure!
Using TIVIMATE and Solos URL, using Surfshark VPN had it working once using Albania but then quit working, been trying different US and other country VPN’s nothing seems to work now, ???
have you tried without VPN just to see what happens, cuz if it works then it’s not the service, so that would be one piece that could be eliminated from the puzzle
Wait, Amber called me “Dear” so that means I’m special and unique right? lololol
I found that if you don’t have or want to set up a WhatsApp account or Telegram account that the chat through the second Alibaba site listed in the first post of this thread (the company website) works great. Chat what has been suggested (DO NOT MENTION “IPTV”) and in my case “she” got back to me in a couple minutes. But I suppose this depends on the time of day in China and you may have to wait a couple hours depending. She will also give you all your credentials right there in the chat after you pay. I took a photo of that chat page for future reference if needed.
Do you guys really think Amber could be a bot?
Translation: don’t ruin my fantasy.
Yes I tried without VPN. Amber Baby chatted back that a VPN was not necessary. I am thinking it may be my ISP blocking that url. Just guessing at this point??
Don’t think so, I’ve had some extended conversations with her. She sends me emoji hugs and kisses all the time. She’s sent me pictures of herself, don’t tell me she’s not real.![]()
From her perspective “you don’t need a VPN”. From your perspective that might be a different story. Opinions on that vary widely here, but I think most would opt for the security of a VPN.
Totally agree with that. I always use a VPN. Thanks for the reply
I think that’s her in the background. But I think I’ve gone far enough here…
oooookay….what ever you say @PapaS
