Best iptv services with no buffering
Ive been using Apollo and its starting to freeze and buffer a lot. what is another great service with low buffering and mulit connections.
Apollo works a lot better in tivimate for some reason if you’re not already using it at least this is my experience
I have used Apo…for a few years and the buffering issue is real, with or without vpn. Of course when you contact support they will walk you through a myriad of tests but essentially, it buffers. From my experience, Tivimate did not help, I also believe it to be a great IPTV player, so I cannot fault it either.
I am leaning more on blaming the device and the overall internet configuration. I think the device either helps or hinders depending on the type of device and configuration of your wifi network. Any glitch in the wifi signal significantly affects performance of any of these streaming services or players and we all know the infamous throttling practice of certain internet providers.
When I cut the cord about 10 years ago. I went full in. I had a AV company come to the house and wired three rooms. All my Nvidia shields are hardwired to the router. I rarely get any buffering and when I do, I use protonvpn.
