🥇 Best IPTV in June 2026 - Wholesale $2/mo & Alternative
Hey @teehar ….i’m an android here, but checked out uhf just for the hay….and if it works like they say then wow….nice product….pretty slick
Just passing on my experience. I have been doing this type of TV service for 6 years and I do not sign up for a long period of time until I am shown they will be around a while. I other words a month first the 3 months then usually another 3 months the 6 months. I got to have a service for over a year before I do linger term. Unless the service is really really cheap. I have one like that so paying around $50 for a year I have done with the thought it will disappear. So far it has not.
Strong service - 19 Dec 2025 info
Me too. UHF works great on iPhone and iPad. I have Smarters Lite too.
Hi Mike. Where do you find this info?
What is your Main?
If you are a reseller you will get access to the providers Telegram channel.
Is Strong 8k the best one to get? What are the other options
Try these
FYI: Anyone that has Mega using MYEPG, you will need to login to MYEPG site. You will need to select Downloads and copy the WORLD.GZ link Old links aren’t working any more. MYEPG site now has a Shorten URL link too.
Best is gonna be subjective, as what makes me happy may not do the same for you…. but Amber offers 5 different services, with a free 24hr. trial for each one. others may chime in here an say what they like or dislike about a particular service or already have. As you have time start reading at the top of this topic and get some clues…. Good Luck….
Red X. I’ve had it for 5 years it’s pretty good, but stuff happens from time to time and I’ve never wanted to pay for 2 services until I found this $35 a year Strong 8k
Shuggy posted services sold by Amber
Do any of the listed services have 5 connection option?
And Please everybody, Remember this is very IMPORTANT….
In the chat ask Amber Baby for Strong 8K. Do not mention the word IPTV in any communication through the ali website. She will also provide you with a trial if you want to test before buying.
ababy2
Amber 8k: sometimes it works, sometimes it doesn’t. Is the solution just to change the url? How does that work for xtreme code?
I know the service is cheap as hell, but a bit of stability would be nice :joy:
What’s the difference between all these services? Is there a description of each somewhere?
If your Strong 8K is no longer working try changing to one of these Xtreme Codes
Some users using vpns can sometimes have to switch location server IPs. If you’re getting no channels thay load, disconnect and reconnect with a different IP and see if channels load.
The cf-hi ones wouldn’t work at all. I got the hi-world to work…. For now…..
