šŸ„‡ Best IPTV in June 2026 - Wholesale $2/mo & Alternative
is it one connection? one month? on year?:thinking:
Those prices are for 1 connection for 1 year.
Has anyone had success using the m3u links provided by Amber Baby for Strong 8k ? She provided 5 m3u links and none of them work. All the xstream code versions work fine.
My built-in IPTV player for Formuler Z11 Pro Max does not have capability to put in separate EPG link for xstream code setup – but does permit this with m3u setup.
Try - This tool allows you to convert your username, password, and host information into an M3U URL format. Simply enter your details below and click the ā€œConvert to M3U URLā€
Used converter. Link same as Amber’s except Amber’s has ā€œoutput=tsā€ at the end. Neither link with or without the ā€œoutput=tsā€ at the end worked. Tried with and without VPN, using Smarters Pro, and VLC Media Player. None will connect. I can use Tivimate where I can use MyEPG with xstream setup. Formuler remote buttons make the built-in easy for wife to use. TiviMate would require some relearning.
So you can use Xtreme codes to log in? It should show your epg, I don’t have a formuler, but anything I put Xtreme code in for I have the epg and every thing populate with out having to add anything.
It may just be you need to alter the m3u link for the epg to work when you put in the m3u Amber sent, look at them and see if one had XML after the server and before the username, if not take the one you put in and replace the m3u with xml and try it.
Anyone having connection error message - change to latest url
Whoops deleted my reply.
Are these for strong?
Yes. :+1::+1:
For the first time since I got Strong couldn’t connect today. Was getting the http data exception error. Changed to one of these Xtreme codes and all good again!! Thanks @MikeN for providing these!
My Strong URL has ā€œsovietā€ in it. Is that the same one you had that stopped working? I’ve not been on Strong in a few days as it’s my backup.
No mine was different. My backup as well except for some live sports. The NFL games feed are sharper than on my main service
My strong was out all channels. I was using ott.me. Switched to next one down and everything is working again.
My Strong has not worked for the past two days.
Thanks. Just saw that and tried it. It worked. Not sure why these posts don’t show up under ā€˜latest or new’ posts…
I agree. The only issue with 8k from Amber there was not catch-up on my subscription.
I got Strong 8k today for a backup, everything went smooth and is running great! Thanks everyone :smiling_face_with_sunglasses:
Used Xtreme code for my TiviMate Premium
Does anyone have a good suggestion for IOS (i-Phone) apps to run strong 8k on?
uhf is a pretty popular one.
