I searched the site, but didnāt see very many comments regarding Eaglecast tv. I got their 48hr trial while I was looking for a replacement for Apollo, it seemed to run at least as well as the service I decided to go with. Iāve got some noobs to this type of thing that I want to ensure they follow the rules before I (might) invite them to my new service, which is freakin awesome so far! So has anyone used them, or are using themā¦.pros/cons/etc?
I was able to get the private server addressā from amber, problem is now absolutely no volume output on any of the private servers, and now itās even effect the public server link. any solutions?
Try clearing cache and rebooting your device - there is something causing your issue.
Been using private url without any issues on multiple apps including Tiivimate
Some have brought service from sellers at a higher cost having same issues and poor support
Not sure what you are getting at. Strong is my backup service but itās incredibly good and I would put it up there against any other service Iāve tried. You must be having some issues on your end but from your post there is no info to help you with
UPDATE #2: Opened app this morning and again not working. I give up.
UPDATE: Solved it for now anywayā¦. so for anyone else out there having to same issue. I went back into the! Tivimate app settings on my ONN box. Cleared the data, not the cache but data. Started fresh entering a xtreme url etc and itās working perfectly. I think this is the 2nd time Iāve done this (Iāve been screwing with it so much I donāt remember. Lol) I believe there is something corrupting the tivimate app. IDK. Maybe someone on here more knowledgeable can elaborate? For now tho, Iām good to go. Thx for all the feedback!
Im having the same issues. Everything was finally good for about a week and now no playlists work. I had Amber send me 4 new private urls and none work. I have had her send me numerous urls in the past also. This has got to be a tivimate issue. I guess Iām going to clear data in addition to the cache and start over. Iām about to give up completely tho.
Yall, I signed up with Amber 8k less than 2 weeks ago. Every other day my service goes down. Every other day I reach back out to Amber, and she gives me at least 5 new urlās to new servers. I then go down the list each time and maybe by the 4th url I enter, I find a working server. Then by the time I have backed up those latest tivimate settings from whatever device i used to test and find the working url, send that backup to the other 5 devices that will also need to be updated, restore each device with the new fileā¦.by the next day the servers are all bunk and have to go back to Amber to get another list of 5 new urls. Lather. Rinse . Repeat.
Preexisting on my end:
I only useTivimate as my main Player (except when on car navigation screen use Smarters with the old android/fermata auto hack)
I run about 3 different IPTV providers as back up for my backup, never any issues unless one of them changed their server and forgot to tell the rest of us new address
I donāt use my VPN(s) (I know, not smart but got lazy on it 5 years ago- no threats or throttling from ISP despite my carelessness) unless Iām needing to torrent-
never use ISP (Suspectrum) DNS, set in my router to Quad 9 or google
With all of that- can someone advise me on if its a āmy issueā or ātheir issueā thatās causing this Groundhog day bullshit? Thanks yall
I wish I had a solution for this, but it just magically started working again. My only guess is I use a soundbar and the audio somehow got desynced, when I switched over to the private server. After about half an hour I went to check it again and had sound.
Hi everyone. Iām new here and new to this whole thing. I purchased a ONN. 4k Plus that was preloaded with a few apps and setup just the way troypoint does in his videos. The preloaded apps are Stremio, OnStream, IBO GOLD, and SurfShark. I understand what each one does and that IBO Gold is the one that has the paid IPTV, but I am now trying to replicate the process and give one to my dad. I like IBO but I also am considering trying Tivimate and a different service with and an EPG so its easier for him to navigate. I understand that everyone in this post seems to go through the service mentioned above, but I was hoping to see if anyone has an unbiased opinion on a different recommendation as it seems many people use this service as a backup? I would like to know what they use for the main service in that case. Note: Still learning so I will likely have follow-up questions to whatever you reply. Thanks in advance
Can you message me some recommendations for other providers? or reply here, I dont want to break any rules, new here. I have GOLDEN OTT but the reseller will charge $350/yr lol so i am trying to replicate the process he did on a new device and want a reliable provider
@alerch Welcome to the BEST STREAMING SITE in the Universeā¦if you read through this post, there are tons of streaming service ideas for you to get trials on. Many have branded Tivimate apps that you can use if you purchase their service. Get a few trials and see what feels good for your pricepoint.
Thanks for the input, looks like a lot of people struggle with reliability in here. From what Iām reading, the most reliable are the invite only servers and they dont advertise. for example my current service is through GoldenOTT Team and the reseller wants to charge $350/yr. seems a bit excessive. Iāll take a look at the link you posted now! Thank you for the warm welcome!!
The Amber services mentioned here work well the vast majority of the time for max $35 a year. Sheās added private URLs for several of her offerings which is helping even more. Iāve never heard of any service wanting $350 a year. Nobody in their right mind would EVER buy that.
Welcome! That is straight up Robbery. Please do not ever spend $350/Year for an IPTV service. I use Amberās Strong 8K as my backup but honestly it is one of the best IPTV services you will find. And for $35ish/year you cannot beat the price or the service from Amber. I was lucky enough to get invited to an incredible invite only service a few years ago. I invited a few folks here but then they had some issues with some people advertising the service and implemented a strict policy that if someone is caught doing uncool stuff they and the person who invited them will be booted so I stopped inviting anyone I donāt personally know.
Get a Trial of Strong 8K from Amber. you wonāt be disappointed. All the info you need to get setup is in the very first post in this thread
I can only agree, the customer service from Amber is way ahead of my primary service. I have had her strong service since October ā25. Iāve had 2 occasions to get in touch with her and both times she replied quickly and courteously, problems solved very quickly. For a cost of 1/10th of your present provider. For me itās a no brainer.
@Peter9 yes, but it seems that since this second device will be with my dad, if he has any problem/issues I wont be able to help him out very fast. So even if Amber is fast to reply to me it will be a whole issue of explaining to an old man what to do. I know my friends with the current service we have with Golden have never had an issue in almost 2 years. I just find the price very unreasonable and Iām sure the reseller wouldnāt be open to teaching me how to set it up myself for good business reasons
@MikeN Yes, ShurfShark has been amazing to me so far. I think what I like most about all of this is learning this whole process. The next thing I want to focus on is finding an EPG that I can use with IBOGOLD just to make it more visually appealing. Iāve always been into jailbreaking stuff since the first ipod touch came out so this is fun. I wasnāt a fan of the firesticks, they were too slow and clunky but the ONN. 4k plus is very smooth. Has anyone purchased the Nvidia Shield and how would you rate it, price aside?
