Originally published at: Best FileLinked Codes for September 2021 (New Codes Added Daily)
The following guide provides a list of the Best Filelinked Codes for Firestick/Fire TV and Android users. Since there are hundreds of Filelinked codes available, this is a common topic we see on the TROYPOINT media properties. Thousands of cord-cutters use various Filelinked codes to access and install their favorite Streaming Apps, device cleaners, modded…
I downloaded filelink from Troypoint rapid installer. I put in the code 44444444 and then it asked for a pin? A pin was not asked for on the Troypoint video. Does anyone know what pin I am suppose to put in?
Dena…
Scrap the all 4’s
Use 12341234…
Thanks @zorlac I just saw that on the lastest Troypoint email! I swear, the last few emails he’s written have been intended for me!!! The 1234 worked great.
I don’t see Filelinked for download at TPRAI ?
Is there a secondary app I can use with codes?
Hi @LadyBoss
Try unlink
Unlinked is working just fine. Follow above.
My bad @LadyBoss I said Filelinked but what I meant was Unlinked. I seem to recall that filelinked can’t be found or does not work any more. Sorry for the confusion.
