Best EPG (Electronic Program Guide) for IPTV
You are the bomb diggity., I’m sure there are way cooler ways to say that, but thats my cool :zany_face: Gonna give that a go today, since I did add bout 1/2 doz. epg’s yesterday. Be well, & keep fightin the good fight, as I like to say.:victory_hand:
On the same subject line for tv glass. Miki do you know how or where to find info on how to assign guide for channels similar to tivimate ? I have read their guide and don’t see anything info like tivimate. Thanks.
I will have to take a look. I’ve been kinda busy as you can imagine. If I find anything I will let you know.
So you long press on a channel and then follow the on screen prompts.
I have Strong 8K, but MyEPG does not ring a bell. I would be interested in checking it out… if I don’t already have it under a different name.
On a different note, I think TREX is also in the same class as Strong 8K.
Here you go. IMO it makes a huge improvement to the Strong EPG. There is a Trial as well as instructions on how to install in tivimate. There is also a link to their Telegram group on the website which is very responsive
Is there a good pay EPG that takes Pay Pal for payment? Thanks
Been using IPTV Editor for two years. Worth the $15 yearly fee
@wtr1019 dors that work good on Amber services
That’s more than twice the cost of MyEPG which works fantastic with Amber’s services.
@SoloWarrior ok thanks for reply will check it out
No idea what amber services are sorry.
@wtr1019 ok thanks for replying
Iptv editor is fully customizable. You don’t need to have a specific provider. You add,delete channels and categories. Make your own favorites make your own categories. Change logos of channels. Remove duplicate channel names.
It’s not just an epg
What is the 5 ip limit?
Iptv editor has no limits. 30 users can be on the IPTV Editor URL. There is no connection or stream count. After 30 users who can have 10 simultaneous streams. Than you need your own domain.
These editors aren’t comparable.
Understood and i don’t want to mess with doing any of that. I want an EPG that works. There is no work on my end using MyEPG. It just greatly enhances certain IPTV services. The service I use it on is my backup so I don’t really need all that customization
All of a sudden I noticed it not updating last night. Is anyone else having trouble with myepg?
I got it back working. Now that the myepg.top site has a url shorten function it was super easy. I just deleted my epg sources and manually typed in the shorten version and I’m back up…finding out about myepg has been a real blessing
Personally, I prefer dispatcharr over editor. The EPG guru project dwarfs a lot of EPG groups by a a large margin.
Granted much larger learning curve but still super powerful tool.
Not having any issues with myEPG here. I have my EPG set to auto update once/day in tivimate unless I manually choose to update. Just updated and all EPG’s including MyEPG successfully updated
I suggest you contact her via the same method you did before. Sorry can’t help and won’t send a PM.
Also have you read this?
