I have been attempting to send bitcoin payments out to several different vendor wallets for IPTV services and EPG guides through Cash App and they keep blocking them……message says there AI and other systems recognize them as potential scams and are doing it for security purposes I attempted to send a payment today to my Coin Base wallet and it worked for only the first attempt I made…succeeding sends got blocked
Like so many who get frustrated with crappy EPG data, I am just getting started with learning what is needed to find that happy medium between effort and return on that effort. IPTVEDITOR needs content… can I assume the EPG url allows access to the underlying data? As a supporter of the editor / manual approach, why do you feel like it is better than purchasing one? Cost? Quality of for sale EPGs not that good?
Great question, I would like to know that also.
Easy decision, Spend the $7/year for MyEPG especially if you have Strong 8K or a similar service. Unless you like to spend countless hours manually tinkering
When you say a “similar service” to Strong 8k, what exactly do you mean? I use Apollo integrated into Tivimate. Although Apollo has it’s own EPG url, that works “ok”, I would still be interested in adding something better. Would MyEPG work with what I currently use? ![]()
I don’t see Apollo listed but they have a Telegram group. Might be worth it to ask your question there to see if it would help populate missing EPG info in your channels. It works great with Strong 8K. Well worth the $7
Thanks, I did message them, waiting for a reply. ![]()
Am liking IPTVEDITOR for $18 a year on cloud. So far. It’s working better than other choices, plus it has lots of flexibility with tech configuration l. Have MYEPG and it just seems to not work with NEXTPVR (my PC DVR choice).
Can you I ask you about IPTVEDITOR? I just purchased a year subscription, uploaded my provider accounts and produced what I had the options of creating a Xtreame Code and M3U file. What’s point of this? I’m looking for a fully supported EPG link for the data in my guide player TiViMate. Can you elaborate on this or share any good reliable resources for paid EPG service?
Firstly - Welcome!
You should read up some first. Check out the Rules and Regs & get familiar with the “lay of the land” so to speak. You have not been on here long at all, so please keep reading and use the search right next to the rules up top right. Cosider becomeing a Patron and it will open up another world of info you can access here. Good Luck & Best Wishes.
If you have one of the supported IPTV services check out MyEPG. I have Amber’s Strong 8K and MyEPG greatly enhanced the existing EPG. Only $7/year and they will give you a Free trial to test it out
Just signed up for the EPGs for Amber services. The EPG worked great with Tivimate. Easy install and good prices. Very helpful on telegram as well with questions.
What do you suggest for someone that has their subscription from one of the many, many resellers, with respect to deciding which EPG to buy? Would anyone ever actually share who their source is? I have a sub from non of the options offered. Thanks in advance.
I use MyEPG for my Backup service. You have to have one of the listed services that myEPG uses in order for it to work. You are a Patron so you have access to the locked IPTV services where there are plenty of posts from people who share who their IPTV service is. Perhaps I’m not understanding your question?
Specifics will help clarify. One of my services is from a reseller called %$#&&. Knowing who is at the top of that tree would help with getting the right EPG. Thanks Warrior.
Shouldn’t these IPTV conversations be in the IPTV category??
Figured the thread on EPG would be the place for an EPG discusion. Move it if that is what is needed.
Im just saying when providers are being named….
Epg discussions are fine but ventured into the violation of our rules naming an unverified IPTV service. @LetsDoIt If you could please remove that I would appreciate it, I hate flagging stuff.
Done.
Apologies for screwing up.
