OK, so I tried Diggz Xenon Matrix, installed fine with all addons but for some reason I was not able to modify the menus, very confusing. Before KODI 19 I used Titanium and it was extremely easy to change the menus. So, can anyone suggest any KODI 19.3 build that I could easily change the menus?
I was a Xenon user most recently. I am no expert, but I was able to modify how it looked by playing around .
I am certain some will jump in with the actual process to follow .
After advice I switched to plain Kodi with my favorite addons .
I found that advice worked well abd reduced load on my android tv box.
