Best AppLinked Codes for Firestick/Android
Originally published at: Best AppLinked Codes May 2024 for Free Streaming Apps
The following guide provides a list of the Best AppLinked Codes for Firestick/Fire TV and Android users. The best AppLinked codes are 5555, 7777, 8888, 6464, 3333, and many others we include in this list. AppLinked is one of the latest FileLinked clones to hit the streaming community. With FileLinked Not Working, many are now looking…
Thanks for including AppLinked on the rapid app installer and the App Store codes! I’m sure there are a lot of Troypoint members relieved that there is a suitable replacement for filelinked.
I’m not able to update to version 1.0.2. What gives?
Troy point has the best info. Been using Troy point before they bought downloader.:+1::heart:
For the last few days I have not been able to use any of the stores on Applinked, including their public store. Is anyone else having this problem, and is there a solution?
Check out the latest codes that troy has posted.
Thank you for your reply. I tried the first 2, 5555 and 7777, and the message was, “Code does not exist or the store contains no applications yet. If you created the store please goto the website and add applicaitons!”
I found that my version of Applinked was out of date and never automatically updated. I also found that the link Troy provided had been changed by the developer. The new link is 475057 and the newest version is 2.0.2.
I had to use the link applinked.store/api/apk in downloader to get the right version, but it works perfectly now.
Thanks for your help and input, and special thanks to Mike at Applinked for walking me through this.
