Best Android TV Boxes
Originally published at: Best Android TV/Google TV Streaming Boxes in 2025
The following guide provides the Best Android TV Boxes in 2023 for unlimited streaming capabilities. Android TV Boxes are streaming devices that provide content via applications and APKs for viewing Movies, TV Shows, Live TV, Games, and much more. There are hundreds if not thousands of Android TV Boxes available for purchase today that come…
Can I ask please is this model the UK clone of the Onn 4K plus, Thomson Streaming Box Plus 270
No, it’s a clone of the onn 4k pro. Which has the s905x4 cpu. The plus model has the s905x5m.
If you are wanting an alternative to the onn 4k plus, the xiaomi mi box s 3rd gen has the same specs.
That’s great, thank you, i assume you can side load with this as well
Yeh you can sideload on em all.
The Chinese are advertising boxes Android 15, 8GB ram and 128GB storage, and putting on Apps is as easy as a android tablet. They should under 40 Dollars, if they can be imported.
Not many AOSP boxes for under $200-$300 there! Shouldn’t they be cheaper than GoogleTV/AndroidTV boxes?
Just do a Google search for “T95 Plus for sale” and you will see many results comparable to the ONN
Prices for Android TV and AOSP system boxes are all over the map. Unless you are on a very tight budget, it is better to pay a bit more for a device with quality hardware that will last longer at the outset and stay away from the large quality of cheap boxes from China that tend to overheat and lack any firmware updates to fix system bugs. Troy has addressed brands and devices he recommends here.
Just to give an alternative viewpoint. Before using my ONN Boxes I had 2 T95Z Plus boxes from China and used them for about 6 years. Zero issues, no bugs, Android updates are overrated on AOSP IMO. Never shut these boxes off, never cleaned them no issue with over heating whatsoever. The cheap china boxes get crapped on here just saying I had nothing but a great experience with mine. Posting for an alternative viewpoint to the majority
I had a T95Z also. Reasonably priced, liked the looks of it and it ran ok for 2 years and then started freezing up with the heat buildup. Moved on to newer, better devices with more advanced hardware/firmware after that.
I have a T95Z Plus box. It’s garbage.
One man’s garbage is another’s bounty! :rofl: As I said they were outstanding boxes for me for at least 6 years.
