Best Android tv box
Hello,
What is the best but affordable Android tv box please? I use it for streaming but i need 3 of them and cannot get an expensive one. Thanks
What do you consider expensive? What is your budget for each box?
There are quite a few and opinions vary. Do some searching on here and you should be able to narrow it down. As @AMD237 asked, what kind of price point are you considering?
lots of budget options for “android tv” box. Personally I would go with the tivo 4k for multiple purchases and its reliable track record.
Depends on your budget… thats a loaded question. Use the search lots of options.
As i need three of them , may be around $50 to $70
I know it is better to have 4gb ram but do we need 64 9r 128 rom ?
At that price point you’re better off just getting a 4kmax.
You can install 3 apps and habe everything you need.
First Android box that popped into my head in that price range was the KM2.
MECOOL KM2 Plus Netflix Certified Android TV Box Unbiased Review (troypoint.com)
Lots of people here seem to like it. I have the KM6, a little higher end, and a little more expensive…but I really like it.
MECOOL Netflix Certified Android TV Box KM2 (2-Pack)
I install IPTV professionally and right now Google Chromecast with Google tv (HD) version is $20 and performs extremely well and ONN Walmart box is $20 too but stock has been extremely limited for months after that TiVo stream 4k is great but $50 but if you catch a sale they’re usually $30 and you can get firestick but I personally don’t like any of the cheaper models only the expensive ones seem to perform nicely
Just checked and the tivo 4k is $30 at amazon.
As @TXRon said, the TiVo Stream 4K is a great device if you can find it at the $30 price point. We have a few of them. Moved to those from the Firestick a while back. I’ve updated to KM2 & Formuler Z10 Pro Max along with a Shield Pro but have a couple family members and friends still using them
What about Chromecast with Google if you want cheap.
I have a few of them but i never thought ww can install app on it. The google chromecasts works like a receiver from google app. Correct?
What is ww? The chromecast is a streamer like the Firesticks, tivo or even roku. Each works differently with different settings and setup, but do virtually the same thing.
Thanks for your feedback. Can you please send me the link for the KM6 ? i looked at amazon.ca but i wasn’t able to find it . Thanks
Can you kindly send me the link please? Thanks
Amazon.com: TiVo Stream 4K – Every Streaming App and Live TV on One Screen – 4K UHD, Dolby Vision HDR and Dolby Atmos Sound – Powered by Android TV – Plug-In Smart TV : Electronics
https://www.amazon.com/TiVo-Stream-4K-Streaming-Plug/dp/B089655HQV/ref=sr_1_8?crid=2KIW28SP4SNJM&keywords=android+tv+box&qid=1673196091&sprefix=android+tv+box%2Caps%2C592&sr=8-8
https://www.bestbuy.com/site/amazon-fire-tv-cube-3rd-gen-streaming-media-player-with-4k-ultra-hd-wi-fi-6e-and-alexa-voice-remote-black/6522377.p?skuId=6522377
Also keep in mind there are boxes that are not “Netflix, Prime etc certified”. If you’re a user of any of those double check and make sure they are
