Best Android box plus best IPTV provider
Hi All
Its been a while since i talked to you guys.My current provider account is closing so i am looking for the best{in your opinion} iptv service provider that is reasonably priced and also the best quality android box.I need a system that works well with tivimate.my android box needs to have 64gb storage minimum.
Guys any help you can forward will be most gratefully appreciated.
Keep up the good work
Sincerely
Michael
I believe the best Android box hasn’t changed. The nVidia Shield gives you a smoother and more reliable experience. I’ve used several others, and they always seem to operate a little slower than the N.S. You can find some cheaper boxes that will do the job if you’re concerned about price, as the N.S. will run you around $200 regular price.
Unfortunately for the OP, we can’t discuss IPTV services in this thread. But the link Miki shared should point him in the right direction. Since the 2nd part of his question was about boxes, we can discuss that and I second the Shield Pro. So much debate around whether Formuler or Buzz or any of these box producers have finally “caught up” to the Shield. I have two Shield Pros and I still wouldn’t trade them straight up for any box out there. Some boxes have definitely “caught up” strictly specs speaking, but IMO there still isn’t a better all around device. Of course I wish it had more memory, and wish Nvidia was coming out with a new model, but my opinion is from years of use (and abuse from my family lol), these things just keep working great.
A few unique features of the Shield Pro that sets it apart (aside from memory/cpu,etc):
-ACTIVE cooling-not found in IPTV boxes almost anywhere
-Nvidia Shield app that you can control the device from your phone or “find my remote”
-Bluetooth, motion activated backlit remote…super awesome feature, best remote out there imo
-Upscaling-we can debate this, but it is still a cool feature to have to add to the full package
IMO spend $50 and get the ONN 4K Pro. Better bang for your buck. Unless you are a hard core gamer no need to shell out for the Shield
I love my Shield,best streaming device I have ever owned.That said,if price is a concern then the $50 onn pro is a great choice.
What’s wrong with your current box? If you were using it with Tivimate without a problem, why change it?
Can we even purchase the ONN PRO 4K up here in :canada:?
Not available from Walmart Canada. There are some on eBay from resellers.
Hi MarkxG thanks for your advice on the ONN 4k Pro.I just spent some time reading various posts and the comments are very positive.My problem is i live in Ireland and i just checked in with amazon UK who don’t have it listed so that’s a problem for me.Keep up the good work and thanks again for your help and also your fellow workers.
Kindest regards always.
I’m in the same position. Seems bonkers that Walmart doesn’t have any sort of international retail partner in place for their own electrical/tech items. Given how highly this box gets praised in the US think of how well it could sell in that big bad world outside the states.
Hello MikeN thanks for your input.my current system is expiring in a few days and i am not happy to continue with it.Firstly it doesn’t support m3u file or xtream codes and also i can not record.the record feature is for football that may be on when i’m not in and the catch up feature is poor [to say the least].i do not have tivimate but will get it with whatever system i purchase.
Thanks again for your input.
