Best alternative cinema HD
What is the Best alternative to cinema HD?
@Wardylfc20
Lots of options.
I recommend kodi stremio syncler.
Thank you mate most appreciated :+1:
Do you need a real debrid account for stremio syncler?
I agree with Syncler and Stremio. At this point they are the best but both require some patience…can be a bit of trouble to set up but well worth it once you are done. Its really all you actually need together with an iptv service or just an antenna.
I’m going to chime in and please don’t get upset with my honest opinion. Syncler may be valuable for some, but I found it of absolutely no advantage to me at all. I installed it and tried it for a week. In Stremio I already have RD and Orion and adding Syncler gave me no additional advantage. This may be because I only had the free app, but really I already get tons of Sources in Stremio and adding more just gets cumbersome, and has no advantage.
I agree with that and I was the same toward stremio… but that was back then, I have the full version of both and both are da bomb… I hated stremio before I actually got serious about setting it up. I saw you touting how great it was but didnt agree…untill I dug in :sweat_smile:… I like them both and think they compliment each other. The way I look at it is if stremio and syncler aint got it …I can do without :rofl:
I will give it a go see what happens. Thanks
I’m glad you found it helped. I’ve had Stremio long before Syncler and it works flawlessly for me and adding Syncler added nothing of use for me, but as I mentioned my Syncler was the free version and I couldn’t justify an added expense for something that did nothing to improve my streaming experience. Many like it, as you do, and that’s how this hobby goes. Have a great Sunday, back to watching the Olympics for free. Have fun and STREAM ON.
Setting up Terrentio with RD can be frustrating, having to input a 52 character RD api key into a Terrentio form on the Firestick. I have found that if you use the FireTv app you can copy and paste the key on you phone or tablet for it to be inserted into the Torrentio form on the Firestick directly. This makes it much easier!
TeaTV works great for me.
@Wardylfc20
No, infact stremio is probably the best free app for sources around aside from direct torrent download.
Use a vpn with stremio.
In my honest opinion, Orion/rd with weyd and syncler is my fav setup.
Stremio and kodi are my alternatives.
This last 6 to 8 weeks I have not had a problem with Cinema like others here. I get plenty of feeds including 4k. I do have RD and watch mainly TV series. Saying that, I use Kodi with The Crew as a backup. However, Stremio is a good alternative to Cinema
Do you need to use real-debrid to watch Stremio for movies and box sets? I used to share a real debrid account with somebody but he’s no longer interested in it I just can’t afford it at the moment I’m out of work due to my health waiting for have someone my liver cut away Once I’m back up and running I will get other RD account
No Stremio does not need an RD account. You can set up Torrentio lite and do not choose any premium service and still pull many excellent sources. Be sure to use a VPN at all times with Stremio. When setting it up go into “community” add-ons and enable every single one for movies and series. It also has sports, cartoons, anime, hentai, and porn as well as TV, but I use mine strictly for Movies and series.
I agree with Miki stremio is very good even without rd when I first tried it didn’t put the time in it takes to first get it set up and put it aside and started to install syncler+ and loved it then I had some time to play around with stremio and set it up and put Rd in Wich is great but not needed if you can’t afford it right now but it is now what I use most instead of syncler try them both and you won’t be sorry. I hope you are feeling better soon. Keep on steaming
Thanks mate much appreciated
Thanks for your help Miki I will set it up and give it a go
If there is anything we can do to help you in this hobby, do not hesitate to ask. I have only paid for TiViMate life $33/CDN and Real-Debrid and I go for the 6 mth package and after a couple of renewals I get some extra time. I also have a VPN that costs me just over $10/mth cdn. So you can enjoy this hobby for very little money and considering I paid $340/mth in Canada for net, tv, and phones. I have saved enough money to be able to buy a small country. Well ok that is a bit of an exaggeration but maybe 10 more years I can be a king or something.
What is url for streamio
