The new Bell Streamer brings your shows and movies, as well as Google Play apps right toyour TV screen.
All this in a tiny device controlled by our easy-to-use remote with Google Assistant built right in. Searching made easy with Google Assistant.Voice control.Use our simple remote or Google Assistant to easily search for content, pause what you’re watching, control your home and more.
Quick access buttons. Watch popular shows, movies, live sports and events with Fibe TV app.footnote 1 Plus, access your favourite streaming services
including Crave, Netflix, Prime Video, YouTube and many more – all from the home screen.
Launch Netflix apps using the quick access buttons on the remote. SoC
Amlogic S905Y2
CPU
Quad-core 1.8 GHz (ARM Cortex-A53)
GPU
ARM Mali-G31 MP2
RAM
2GB
Storage
8GB
Dimensions
69 x 69 x 15 mm (W x D x H)
Weight
50g
This little box performs well out of the box i liked it overall haven’t used it alot yet but liked it. was released in 2020 and Bell had a promo to recieve it for free so i accepted the offer. Also capable of handling internet speeds 2.4ghz and 5ghz. Only available in Canada Not sure if they can be purchased in the U.s or if they will work there. Price point is high if buying one of these my opinion only.
