I’ve installed this, and gone to settings to change the default to external player, and I have MX Player, but any link I try in BeeTV, it says “Can’t play this link”. Have done a force stop, have reinstalled. Any suggestions?
I just updated my copy of BeeTV from the Unlinked repository…library/store code # 67664537 & it is working fine…populated plenty of streams & loaded immediately on MX Player Pro. Not sure where you are getting your copy from, but you may want to try this location. GL2U ![]()
BTW…I downloaded the AF (add free lite version)
Realitvly new user what is unlinke repository? Thanks
It’s a store of stores with all kinds of different apps…in Downloader or your favorite streaming device browser…search for Unlinked APK…once you’ve downloaded & opened it you’ll need to type in “library/store” codes…the one in my post above is a very good one…another good one is 96960000.
shhhhhh, ACE is listening! ![]()
Sadly, they probably are…& have been for a while
Just because we’re paranoid doesn’t mean someone isn’t out to get us.
ACE is the place. I thought they were just a hardware store?
