Hi all,
I’m using BeeTV v3.7.9 and Real Debrid.
I see less DEB links in BeeTV than in CinemaHD for example. For some TV Shows, I don’t even see 1 Real Debrid link in BeeTV.
I’ve removed my device on Real Debrid and added it again.
I checked again and no Real Debrid on BeeTV for the TV Show I’m watching while I see some DEB links in CinemaHD for the same TV Show.
I’ve been waiting for some time to make sure I’m patient enough but no DEB link is coming on BeeTV.
How is it possible that there is such a difference with the results in the 2 apps ? And why less or no link with the TV shows ?
Is there something to configure in BeeTV ?
Thanks
I have no sound on Real Debrid links with BeeTv, with MX player, non RD links sound fine. cant get MX player as preferred player. tried reinstalling but does not change. Also works fine with cinema and cyber tv with preferred player as MX.
I sometimes have realdebred on movies and sometimes on TV but mostly on neither.
Try some non debrid links on Bee TV. I’m watching a series right now on Bee using non debrid and it’s working perfect.
Cord cutting is continual problem solving and learning. Kodi, Stremio, Bee or you name it app, there will be problems. Stay flexible, experiment and remember, you’re still $aving ton$ of dollar$.
Just went to the next episode and got debrid link, go figure?
I’ve noticed it takes 2-3 cycles before the RD links show up
