Recent updates to BeeTV (after 2.8.5) and TeaTV (after 10.2.3r) insist on downloading media players that are riddled with ads (Titan Playet and TPlayer, respectively)… If you select cancel (instead of install) the app won’t work. I see the guide on Troypoint make no mention of this. What’s going on?
EDIT: Just deleted BeeTV and TeaTV and re-installed the older versions - They are forcing you to install their ad-players now. Goodbye to both!
So I tried FilmPlus, NovaTV, VivaTV and they are also forcing you to install ad-players. The only app I have that doesn’t do this is Cinema. What the heck is going on here???
I have under Player… “Choose default action”… (choose) “play with external player” then u can choose a player… Cheers…
Yes, but I really just wanted to use the internal player - its always worked fine for me and doen’t take up any added space on the firestick. It appears the latest versions don’t have the internal player any more. I loaded MXplayer and it works but I still get the annoying ads (that I never used to get until a couple of months ago).
And yes, I did use the search facility - if there are any other posts on this, it didn’t find them.
