“eyeglass icon on top right to search”? Where is this? (I’m using TiviMate)
If you’re using Tivimate just use the search on the top of the left side pop out. Type in team and then all your feeds from your playlists will be there including times, days etc. not just the ESPN+ feeds.
Thanks Miki. I think I tried that and it struggled to come up with Big Ten+ and ESPN+ smaller market games. I’ll try again.
If your IPTV service carries the game on any channel it should come up @carlbs . I do know, on my service, if they can carry the feed I’m after, but don’t, I can request it and they do their best to add it for me. Have a great day my friend.
Getting TiviMate Premium was one of the best, if not the best,choices I’ve made in this “hobby”. I’ll try the search again for my team, but all the “plus” games are done for the season for me, so it might be a while before I need the search. It auto updated to v5 on my Mecool, but I still don’t see the system picker. I’ll look again. Thanks Miki. Enjoy the temp nice weather in the North Country.
Be sure to go into your system files app and uninstall updates and do a complete power cycle to clear all buffers and any queues. Now on some the uninstall updates doesn’t show so you have to choose uninstall and then it should ask you if you want to replace the existing with the original factory app and yes we do. Then once done with the power cycle stuff, fire it all back ip and have another look. Have fun and STREAM ON!!!
This is in reference to going back to the previous version of TiviMate? The system picker never showed up with the Mecool and other devices on that version either. So I was hoping it would show up in the new version like some are reporting. Is there another reason you are suggesting to uninstall updates? I also have 32 internal memory and since I’m not a regular recorder, I don’t really need a usb drive for more memory so system picker isn’t a priority right now (it just sounds cool and would be nice to have lol).
No this is for any devices that had Sys pick issues.
Ah, so you are talking about a file app like X-plore.
No you go into your system apps, find your “files” app and then uninstall updates or uninstall and revert back to factory. Then power cycle everything and see if you can now access the file picker. Then using X-plore you should see the files you want and accessing “use this::::::” you should get a pop up asking for permissions. There are other ways but this is about the easiest. Here’s a link to help understand the process better.
I haven’t tried this on TIviMate, (only on my Smarters based IPTV app), but if you scroll all the way to the left, you will get the spyglass icon at the top of the TiviMate column. Try entering your team choice there and see what you get. Good luck.
Just wondering if anybody with a legitimate Bally subscription either stand-alone or on their TV service are having the same problem.
Bally not working for me either.However,I have other apps,that I can use.bally is not the only app for watching pro sports.
Yes the ****** games also,Bally sports is on it’s way out,use the mlb feeds you should have no problem there
Balley sports games only available locally in Wisconsin. You need to use MLB.com or find it on a an opponent’s feed
If you have a VPN that picks up a Milwaukee server that might work
Bally Wisconsin on IPTV does not broadcast the local baseball or basketball teams regardless of whether it’s a home or away game. It shows the pre-game stuff and then switches to usually women’s basketball. The only thing that works on IPTV is MLB.
Just an update on this issue. As of yesterday Bally was showing the correct game on one of my IPTV providers. However on my other IPTV provider it was not. Go figure.
i have comcast in fl. they no longer carry Bally Sports due to Bally filing for bankruptcy that means tampa bay rays games are not being televised
