B player will not install
Hello again.
I have an Amazon fire stick, real debrid, and surfshark VPN. I also have film Plus and Bplayer.
When attempting to use filmplus of late, I receive a prompt to update Bplayer for best experience. When I attempt to update Bplayer, installation fails.
Any information or insight about this minor problem would be greatly appreciated.
Thank you,
M.
I knew someone else with that issue and they had to uninstall Film+ and get the latest APK and do a reinstall. That’s the only way they could get it to work.
Hello, Miki. Thank you for responding.
Do you mean uninstalling Film+ and then installing the latest version?
Clearly no expert, but updated the unmoderated Film+ last night, but the BPlayer wasn’t resolved.
Any info or insight appreciated, and thanks again for responding,
M.
Yes. The instructions were to completely uninstall Film +, install the latest updated version then Bplayer will update and work just fine. For some it appears the last update has somehow broken the update of the Bplayer resulting in this issue. So updating an older Film+ is the issue. Uninstall and get the latest version.
Having this issue again, so will follow your instructions, assuming they haven’t changed.
Trust you are well, and thank you for all of your help,
M.
