The MQ7 mod is the best and most configuralble skin I have ever installed It’s not a build Just a terriffic skin You must install your own repos /addons You can find it with instructions in the Kodi Forum Skin/Aeon/MQ7 . Latts repo and marcel veldts beta are rquired to install. I prefer to load all of the repos I use and addons. preinstall all prequisites in the basic Kodi Skin 1st. then the skin loads very fast. On a new build using a windows computer I start with a freshh install of Kodi On and android device maybe you want to just clear data and cache in the apk or fresh install It’s your choice
Thank you for letting us know.
I have a few skins I used to use. I’m not a big build fan to be honest.
