How do you turn off auto fram rate in Nvidia Shield Pro 19 ?
Mine does not have an AFR. There is a “Match frrame rate (beta)”
If tivimate is the issue, auto frame rate is in settings>>>playback
I can’t find any playback settings in Nvidia Shield Pro 19 .
Not sure what you’re looking for in the shield settings. There aren’t any specifically labeled playback. Display & Sound are where you’ll find the settings that are available to you.
Nevermind he already knew about it
Knew about what?
The match frame rate you told him about… i forgot you mentioned it already.
Lol. All good. Tx.
