Asus RT-AX3000 power extension cable?
Does anyone know what size of the power connector on fhe RT-AX3000? I don’t want to use an extension cord to connect to my UPS. I’m not having any luck getting the info from Asus.
This seems like the one - at least the description seems to fit the model you have inquired about… hope this helps.
Thanks.
Did Reece help you out?
I have the same router and I could get you more info if needed.
I could up load a picture if you want.
I ask because I think mine is 12V.
Thanks for checking. Reece pointed out a replacement power supply and Asus support replied " the connection is either 4.0mm or 5.5mm". Mine is 5.5mm.
