Does anyone know if an Asus Mesh ASUS ZenWiFi AX Mini,Mesh WiFi 6 System is compatible with an Eero Pro WiFi 6 router?
My best guess is no. They would need to be two of the same brand with compatible models. For example, two Asus Zen Wifi models should work together.
Oh rats! Thank you though AMD237
It sounds like it can work but not worth the trouble, Agree with AMD237 get the same make pods and you’ll be fine. Try to get your router to the center of your house if possible up high on a shelf. Now there is also wall mountable routers.
Thanks Jock! I will just go with all the same.
