Apps in Unlinked not downloading
I downloaded the Unlinked app from the Troypoint app. Every time I download an app it goes to 100% but when I hit the launch button I always get Installation failed message on the screen. It does it with all the codes (12341234) etc. I have a 2nd Generation Firestick with plenty of space on it. I never have this problem with APKTime or other apps. Any reasonable fix to this problem is appreciated. Thanks.
Try to delete the tp app and unlinked app clear all cache make sure you have allow apps from unknown sources on redownload tp app and unlinked reboot your stick and try downloading something and see if that helps . Good luck let us know how you make out or need more help
@Unchained
Do what’s mentioned above but also make sure to allow instal from unknown sources
Firestick is always on install from unknown sources. Uninstall & reinstall both Troypoint & Unlinked apps and still get them same result. It downloads to 100% but when I hit launch I get failed installation screen. Never had this problem with any other app including APKtime, etc. since cutting the cord almost 5 yrs ago. You guys have any other suggestions??
