Apollogroup.tv not working error code 503
Is anyone here having problems connecting to Apollo group TV? Receiving error code 503
Same. Came here to see if anyone else is experiencing an issue.
Me too. Looks like it is out all over. Wonder is server issue ? Shut down?
I googled the 503 error and it says the site is on maintenance mode
I’m still down on Apollo IPTV. Does anyone know what is going on with the service?
My working just fine, are you sure you have the right one, there are so many copycat fake sites out there
My experience with Apollo has a disaster. I bought the 3 month package with the option to have a refund in the event of a problem. I know my Tivimate is installed as I have been using it successfully with other IPTV sites; however, Apollo did not install in Tivimate.
Subsequently, I used Smarters Pro, ICPTV, and Sparkle to no avail. I easily spent four hours trying to get it to work, and was unable to get any positive results.
In the last week, I did not receive any confirmation for support with the possibility that therre might be flawed confirmations, and no response on the refund.
At this point, I have to think that I bought three months of Vaporware.
I have another one down. I think Honeybee has gone down also because I can’t find anywhere to contact them.
The 503 Service Unavailable error is an HTTP status code that means a website’s server is not available right now. Most of the time, it occurs because the server is too busy or maintenance is being performed on it.
A 503 error message can be customized by the website it appears on or the server software that generates it, so how you might see it vary greatly.
How to Fix the 503 Service Unavailable Error
Since the 503 Service Unavailable error is a server-side error, the problem is usually with the website’s server. Your computer may have an issue causing the 503 error, but it’s not likely.
Regardless, there are a few things you can try:
  1. Retry the URL from the address bar again by selecting Reload or Refresh, the F5 key, or the Ctrl+R keyboard shortcut.Even though the 503 Service Unavailable error means there’s an error on another computer, the issue is probably only temporary. Sometimes just trying the page again will work.
How do i find instructions to add apollogroup tv to tvimate?
