APKUpdater is an open source tool that simplifies the process of finding updates for your installed apps.
It provides similar functionality to an app store, but instead of depending on a single source, it aggregates the results from APKMirror, Aptoide, F-Droid, IzzyOnDroid, APKPure, GitLab and GitHub.
https://github.com/rumboalla/apkupdater
Question, is/dose APKTime do the same thing??
Which one do you use?
