Although I think it used to be a little better I still firmly believe that ExpressVpn is the best all around service available. Most of their servers that are labeled with a number that suffixes the location aren’t detected as a VPN which means a lot. In fact it means everything if your service isn’t working because of the VPN. Surfshark gets decent ratings as well because of the price and encryption is good. You can expect to pay nearly triple for Express than you will with Surfshark but you get what you pay for.
I’m glad you have. I tried Express extensively and found little difference compared to SS or even Proton.
in 6 yrs i’ve never used a vpn w my iptv services and never a problem? and basically don’t have any buffering?
i only turn my vpn service on when downloading torrents? and again? never a problem? so far so good so i’ll keep it like that until there is a problem?
just my 2cents altho it’s probaby worth about .5cent now…lol
I do the same.
On the other hand, in the 25 years I’ve been on the net I have never connected without an active Firewall or VPN. To each their own.
I rotate VPNs pretty much every day.
