Anyone experiencing problems with Xenon 2.2?
I updated from xenon plus 2.1 to xenon 2.2 plus .After three reinstalls, i still am having problems with trakt displaying what episodes i have already watched. It displays all of the series and episodes, but Does not check off the episodes i’ve seen in the past… I am synced with track. Any suggestions
i am trying to understand your issue.
In Xenon 2.2 or even older versions Trakt section won’t display all off the episodes you watched. The name of the series will appear and the next episode to watch/continue will be shown. If you didnt complete the show it wont recognize it as watched to move to the next.
Or are you talking about in the subfolders?
I think I’m missing something here.
There was a quick Xenon Plus update to 2.3 if you were still having issues.
Thank you…just got around to checking this… i discover the update yesterday. It was fixed… Thank you for your sponse!!
Hello. I have version 2.0, but I don’t update it because I’m afraid that the addons that I have installed and are not from the xenon build will be deleted or uninstalled.
Yeah not sure about that. I could try it out on my kodi Fork and see what happens.
My guess is the addons will not be on the build but the repository it came from will be. So you would just add it that way.
The other addons should be in kodi in File Manager and you just added them to the build. As long as you dont delete/reset kodi i think they will still be there.
Yes all of your addons are still the 2.3 update… You just pick and choose the ones you want to add like before.
Hes talking about addons he added outside of the build.
They really should still be in their repository on kodi.
Well i was wrong…
I added a repository and then an addon to Xenon Free 2.2
I then changed to Xenon Plus 2.3 Build. I assume this would be the same basic process as you updating from Plus 2.0 to 2.3.
The addon and the repository were both deleted from Kodi/build.
So unless i did something wrong or there is some way to save the “outside” repository/addons, you would have to add them all again manually after updating.
Edit: i realized i had Plus 2.1 on my phone and tried on as well. Same results. Repository/addon were gone after update to 2.3.
