Antivirus for cell home pc and firestick
can any one recommend an antivirus for my pc ,cell and firestick one that really works well with what we do.
thank you in advance
Malwarebytes
xxxxxxxxxxxxx
thank you i will check them out
Hi Miki how are you feeling? How did you wind up getting Malwarebytes on your shield?and is it free or paid version
It was the free version. I have a mini keyboard so that makes it a tad easier. I just used an AndroidTV APK from uptodown.
O ok great glad you got to work. How are you feeling better I hope :+1:
I am doing better physically. Thank you for asking. Have a great week.
Surfshark vpn has a built-in antivirus also.
As a technician since 1998 I love an used Malwarebytes in the field and present. I also used Avast, ESET & BitDefender boot disc. Avast also has a great feature to do a boot scan. This is great as the virus or malware is not running yet as your not in the OS yet. Its alot easier for the Program to clean and or remove when the virus or malware isn’t running yet.
Please see hyperlink below for a great review of several of the best.
https://www.av-comparatives.org/wp-content/uploads/2022/07/avc_biz_2022_07.pdf
I highly recommend Vipre.
Hey all. Just wanted to know what the best firestick cleaner and antivirus software is out there. I’m on point with the firestick and apps and everything is working fine as it should for 4 years but viruses and whatnot advance every year. Just want to keep things clean and running smoothly. I use defsquid now and it works but it free. Paid ones are the best option. Just tryn to find out what yall use. Thanks
The best firestick cleaner is a hammer :slight_smile:
Thanks for the remark
A good deal from the newegg web site
Malwarebytes Premium Security - 5 Devices / 1 Year - Download
+ $17 off w/ promo code EPF4263, limited offer
  • $39.99
  • $59.99
  • Save: $20.00 (33%)
