Does anyone know how to prevent the anoying Adds on some vod sites? I got SurfShark mainly for that reason, but nothing I do will prevent the adds. I’ve tried everything. Any help would be greatly appreciated.
davexxx
Why not get Real Debrid and use a streaming apk? No ads.
if ads are embedded like youtube does its futile to try, if its pop-ups and the vpn is on a router you can try adaway on the box.
use addfree aps if you can there are lots of modded apps out there
What type of device are you using? Phone? Android box? Windows computer?
