Thank you but it does show not found when I search for it in the App Store. When this happens, I use APK mirror (thanks to a suggestion from someone on this forum) and I can download it from there. However, Hulu hasn’t worked when I download from there and I don’t know why. As I stated, I have tried three different times with different versions and none open properly. I am not going to do a factory reset bc I am not going to start over setting everything up.
The most likely problem is the app failed to remove completely, I have seen it happen before although it isn’t common.
You can uninstall via a command line using ADB.
This will most likely allow you to then reinstall by Hulu the normal methods.
It would require ADB access, the easiest way is from a different Android device, streamer or phone, using the remote shell app or another Android ADB app, personally I use ATVTools but it has a small fee.
With remote shell “adb shell pm uninstall [package]” then use "adb shell pm clear [package] "
(Yes, even it it doesn’t appear to be installed)
To find the package name the easy way is to install “APK” app or “apk-info” app. You can also find the com. Package name with most file explorer apps.
It will be something like com.hulu.plus or similar.
I am using the Bookmarker app and love it. Is there a way to modify the app icon so I don’t have to remember what site each app is linked to?
Hi Troy Boys and Girls, just following Troy’s email today regarding Streamfire and Sportsfire, both loaded OK but can’t be opened due to ’having been identified as containing inappropriate material’ or some such wording. Both nor say ‘App not found’
using Firestick 4K max but have older version - worth trying?
How old? Gen 1 and 2 may work (OS5 and below).
Have any of you noticed that the firestick has a dark screen when you first launch it? I have to press the home button or the back button to get it to its home screen. Is there any fix other than resetting it?
Welcome to Amazon’s new and improved interface!
