ADM on Nvidia Shield Pro
I downloaded a few different APKs for Advancdd Download Manager on a Shield Pro. After installing i just get a screen with a top toolbar, but I cant select or navigate throughtout the UI. I also tried with a mouse toggle, nothing is selectable.
Is there a way to fix this? Is ADM still the best way to download files on a Shield? Any alternative suggestions?
I used ADM to download a video in Stremio. It was pretty easy. I then used my X-plore to access and play the file. I only did this as a test. I never download and keep anything.
I installed Advanced Download Manager to an Nvidia Shield Pro. The app opens up and looks ok, however nothing is selectable. I have the mouse toggle installed and seems to work fine with other apps, however the icons in ADM are unselectable using the Dpad or mouse toggle.
Anyone see this before and know how to resolve? Is there another app that will allow me to select and download files to an external HD?
It appears that the Shield no longer supports the ADM. No idea why. I used it as a test a few months ago and it worked fine. I just reinstalled it on my Pro and you’re right, it no longer works. Apparently there is now some missing component on the shield.
Thanks for the validation! Are you aware of a similar app that will allow me to input a download location on an external HD?
I use TiVimate and can choose a storage location using the System picker.
